jeremyweber
Jan 09, 2018Aspirant
MIsmatching router/satellite firmware.
This may be a silly question... But my orbi purchased in december of 2017 from amazon and it has model number RBR40 for the router and RBS20 for the satellites. I see that there is a new beta firmw...
DarrenM
Jan 11, 2018Sr. NETGEAR Moderator
I will have to check if there is a beta firmware for the RBS20.
DarrenM
- jeremyweberJan 11, 2018Aspirant
Thanks that would be appreciated. Also is there any issue with running this combination of models?
- DarrenMJan 11, 2018Sr. NETGEAR Moderator
no you can mix and match the satellites with the router whatever works best for your home.
DarrenM
- DarrenMJan 12, 2018Sr. NETGEAR Moderator
Here is the link to the Beta firmware for RBS20
http://files.netgear-support.com/go/?a=d&i=OGhLlDB9mQ
DarrenM
