jeremyweber
Jan 09, 2018Aspirant
MIsmatching router/satellite firmware.
This may be a silly question... But my orbi purchased in december of 2017 from amazon and it has model number RBR40 for the router and RBS20 for the satellites. I see that there is a new beta firmw...
TedsNotHere
Jun 05, 2018Aspirant
I have the RBR20 with firmware 2.1.4.10 and a satellite RBS20 connected via ethernet cable thru a TP-Link gigabit switch. The firmware for the RBS20 is V2.0.0.64 and when I try to check firmware to update to newest version the status says "Service unreachable" in the status column in the Firmware Update page.
Is this an issue becuase of the wire connection?
Jun 05, 2018Guru - Experienced User
Just manually download the FW file for your RBS20 then manually install it to the RBS20.
