webminster
Dec 21, 2017Luminary
Missing clients in router attached devices list
I've seen this on firmware 2.0.0.76, and on 2.1.1.16. I have a couple of Amcrest cameras that are connected to the network. They do not show up in the attached devices list at all. They have to ...
wp200
Jan 07, 2019Aspirant
I had to reboot the system because of other issues (periodic short network outages, but that's another topic), and now my printer is missing from the attached devices list. Which means I could not print my son's homework this morning....
The printer is connected (it can do a printout of it's status including connection status and SSID), but I can't print because, since the Orbi doesn't "see" the (connected) printer, no device gets to see the printer.
What's up with this?
- freakievinnieJan 08, 2019Star
I have the same problem (Orbi RBK50 - Firmware 2.2.1.210) with my Netatmo Weather Station. Where exactly can I find the option to show previously connected devices? In the Genie app (IOS) my weather station is also not shown.
- wp200Jan 08, 2019Aspirant
You can follow the link in the upper right corner (when logged in from a computer) called "access control". There you can block devices, but you also get to see devices that were on your network in the past.
I removed my printer from this list; this did not help. However, half an hour later my printer suddenly was recognized. It started printing my son's homework.
I quickly gave the printer a static IP-address (advanced > set-up > LAN set-up > address reservation). Hopefully this was a one-off problem....
- freakievinnieJan 09, 2019Star
Thanks for your help!
