webminster
Dec 21, 2017Luminary
Missing clients in router attached devices list
I've seen this on firmware 2.0.0.76, and on 2.1.1.16. I have a couple of Amcrest cameras that are connected to the network. They do not show up in the attached devices list at all. They have to ...
freakievinnie
Jan 08, 2019Star
I have the same problem (Orbi RBK50 - Firmware 2.2.1.210) with my Netatmo Weather Station. Where exactly can I find the option to show previously connected devices? In the Genie app (IOS) my weather station is also not shown.
wp200
Jan 08, 2019Aspirant
You can follow the link in the upper right corner (when logged in from a computer) called "access control". There you can block devices, but you also get to see devices that were on your network in the past.
I removed my printer from this list; this did not help. However, half an hour later my printer suddenly was recognized. It started printing my son's homework.
I quickly gave the printer a static IP-address (advanced > set-up > LAN set-up > address reservation). Hopefully this was a one-off problem....
- freakievinnieJan 09, 2019Star
Thanks for your help!
- GWildMar 03, 2019Guide
Attached Devices is only showing the first 7 attached devices ... missing devices are NOT in the blocked or prior connection lists.
Makes me wonder just how good the security is if the router breaks when 8 devices connect.
- FURRYe38Mar 04, 2019Guru - Experienced User
What FW is currently loaded?
What is the Mfr and model# of the ISP modem the NG router is connected too?How many devices do you have connected? Wired and wireless?
What devices do you have? Mfr and model#?
