jrob513
Sep 09, 2021Follower
Missing Connected Devices
Has anyone had the issue where some devices that are connected to the network are not showing under the Attached Devices tab? I have 35 devices showing connected, however there are a couple of devic...
Sep 10, 2021Guru - Experienced User
Seems like every other time the firmware gets updated, it breaks the connected devices page.
I've learned not to trust it a whole lot.
- iFutzySep 19, 2021Initiate
Hey there,
Exact same situation for me. Orbi reports an alarmingly small list of attached devices. When investigating under Access Control I can see the devices reported as not currently connected to the network. However, I have full control of these "missing" devices through numerous apps.
No manner of witchcraft seems to have them display correctly through either the ios app or the web interface.
RBR50RBS50 X 2
RBS20 X1
v2.7.3.22- FURRYe38Sep 20, 2021Guru - Experienced User
iFutzy wrote:
Hey there,
RBR50RBS50 X 2
RBS20 X1
v2.7.3.22- pablohoneySep 20, 2021LuminaryI had the same issue on the current official firmware. I worked with support providing them logs etc and they discovered a bug. They fixed it and provided me with a modified firmware which works - .23 I’ve attached it so try it at your own risk but for me it has been fine and shows all devices connected.
https://www.dropbox.com/s/7fdsp2kjj9f6xzw/RBR50-V2.7.3.23.zip?dl=0
https://www.dropbox.com/s/ftsfod5sblgtdig/RBS50-V2.7.3.23.zip?dl=0
