jrob513
Sep 09, 2021Follower
Missing Connected Devices
Has anyone had the issue where some devices that are connected to the network are not showing under the Attached Devices tab? I have 35 devices showing connected, however there are a couple of devic...
Sep 10, 2021Guru - Experienced User
Seems like every other time the firmware gets updated, it breaks the connected devices page.
I've learned not to trust it a whole lot.
iFutzy
Sep 19, 2021Initiate
Hey there,
Exact same situation for me. Orbi reports an alarmingly small list of attached devices. When investigating under Access Control I can see the devices reported as not currently connected to the network. However, I have full control of these "missing" devices through numerous apps.
No manner of witchcraft seems to have them display correctly through either the ios app or the web interface.
RBR50
RBS50 X 2
RBS20 X1
v2.7.3.22
- FURRYe38Sep 20, 2021Guru - Experienced User
iFutzy wrote:
Hey there,
RBR50RBS50 X 2
RBS20 X1
v2.7.3.22- pablohoneySep 20, 2021LuminaryI had the same issue on the current official firmware. I worked with support providing them logs etc and they discovered a bug. They fixed it and provided me with a modified firmware which works - .23 I’ve attached it so try it at your own risk but for me it has been fine and shows all devices connected.
https://www.dropbox.com/s/7fdsp2kjj9f6xzw/RBR50-V2.7.3.23.zip?dl=0
https://www.dropbox.com/s/ftsfod5sblgtdig/RBS50-V2.7.3.23.zip?dl=0- josephgrabJul 06, 2022Aspirant
Would this be for the RBR50v2? Or v1?
- iFutzySep 23, 2021Initiate
Sorry... missed this. Yes I've tried an "as new" set up. As devices come online some appear, some don't. All function properly regardless of whether the ORBI console identifies them or not.
