arnb
Aug 13, 2020Guide
Missing Devices and Satellites
Installed router and satellites yesterday, Aug 12, 2020 Satellites showed up as connected 5G with good backhaul Devices displayed 7 of 14 attached and working devices Decided to power down the ...
arnb
Aug 13, 2020Guide
I changed the Lan IP address because my prior router's reserved IP addresses were 192.168.0.nnn and Orbi Router rejected addresses. Also have 5 Broadlink rm3 Minis (IR Blasters) that would need to be totally reinstalled into their app and my Hubitat system, a total nightmare. Easiest path for me was to duplicate the old network. Yesterday after changing the IP the satellites connected and showed good back haul with 192.168.0.nnn addresses.
Mstrbig wrote:Why did you change the LAN IP address?
arnb
Aug 13, 2020Guide
Update: If I look at the system using the Android phone app it shows the satellites daisy chained (as expected), connected with 5g. Logging in from computer shows them as disconnected.
Both app and computer show only 3 of 14 devices as connected.
PS can only get into the phone app by clicking on Anywhere Access, login in fails.
