arnb
Aug 13, 2020Guide
Missing Devices and Satellites
Installed router and satellites yesterday, Aug 12, 2020 Satellites showed up as connected 5G with good backhaul Devices displayed 7 of 14 attached and working devices Decided to power down the ...
Aug 13, 2020Guru - Experienced User
Do devices appear on the RBRs web page under connected devices?
Decided to power down the router for 2 minutes to see if I could get devices to show.
Now Satellites show as disconnected, but have blue light tops, 3 of 14 working devices show as attached. Yes I did a sync and it seems to have worked.
My frustration levels are rising as I cannot determine status of any of my devices. I'm hoping someone has a workaround or answer for this issue. Thank you.
Additional Background info:
Set my own admin password, ssid and network password, changed Lan Ip address from 192.168.1.1 to 192.168.0.1, added 10 reserved IP addresses. I have 5 (working) Broadlink IR blasters that must be totally reinstalled if IP, SSID, or password changes, they are a PITA.
arnb
Aug 13, 2020Guide
The internet provider is Optimum Online
RBR plugged into Arris TM822 cable modem
House about 1800sq ft, one floor, but very long with RBR at one end, RBS daisy chained about 30ft from RBR, then 25ft RBS to RBS. Yesterday, connection displayed as "5g good backhaul", and still seems solid, but looking at gui I would not know that.
FURRYe38 wrote:What Firmware version is currently loaded?
- MstrbigAug 13, 2020Master
I assume you are coming out of 1 of the 2 LAN ports on the Arris and not the WAN port?
It absolutely makes no sense that you are functioning, but some of your devices are not showing up.
- arnbAug 13, 2020Guide
Mstrbig wrote:I assume you are coming out of 1 of the 2 LAN ports on the Arris and not the WAN port?
Yeah you right! It's a mess. I'm considering factory resetting, uninstalling, and returning the Orbi, but I'm getting great hroughput and everything other than the Attached Devices page works.
My Arris has Cable in, 2 phone jacks (using 1), and 1 Lan.
BTW someone asked about the FirmWare it's the latest afaik for router and satellites: V2.5.1.16
I can assure you it's not the Orbi. I install mesh systems almost every day and so far no other brand has come close to the performance of the Netgear Orbi. And yes they have great bandwidth throughput. So it would be a shame to send them back. Ther is something else that is causing the missing devices in the GUI and app. Have your tried uninstalling the app on your phone or tablet and reinstalling it? There's not much you can do with the GUI as you are accessing it with a web browser, but you could reset the browser.
