arnb
Aug 13, 2020Guide
Missing Devices and Satellites
Installed router and satellites yesterday, Aug 12, 2020 Satellites showed up as connected 5G with good backhaul Devices displayed 7 of 14 attached and working devices Decided to power down the ...
Greg00001
Sep 03, 2020Star
I've had the same issues as you. Satellites showing disconnected, wrong # of devices listed. Even after factory resets and starting from scratch after each firmware try I always revert to this firmware. It has been the most reliable and stable for me.
arnb
Sep 03, 2020Guide
The annotation (jpg) below is a sample off the garbage I am seeing. Greg00001 do you have Broadlink devices?
- FURRYe38Sep 03, 2020Guru - Experienced User
What browser are you using? Does this happen in other browsers? Try IE11, Edge, Firefox or opera?
Be sure to clear out all browser caches before entering the RBRs web page.
This only happens when you use these blaster devices?
arnb wrote:The annotation (jpg) below is a sample off the garbage I am seeing.
- Greg00001Sep 03, 2020Star
arnb wrote:The annotation (jpg) below is a sample off the garbage I am seeing. Greg00001 do you have Broadlink devices?
I do not have any Broadlink devices but I have had the display as garage in the past when some of my devices had duplicate IP addresses. I don't recall if it was as bad as yours. Even though the devices were rebooted/powered off they were sticking with the IP address they had after I did a factory reset of the Orbi. Don't ask me why but I had to wait a day or so until they did their own ip renewal. I have around 60-66 devices on my network at anytime.
- arnbSep 03, 2020Guide
It occurs in all browsers; firefox, chrome, edge, opera, and the Orbi app. For the record I use Vivaldi for my go to browser on Windows 10 and Android 9 phone.
Everything worked until I powered a Broadlink RM Mini3, IR blaster. Everything continues to work, including the IR devices, except for the the attached device page
I'd update to v16, RBS first, then RBR lastly, Then factory reset and setup the RBR and RBS from scratch. Be sure to clear out all browser caches.
Start turning on devices and letting them connect. I would try using Edge or Firefox browsers for this.
Icons should appear correctly on the web page and not broken picture icons.
The try your IR devices and see if the web page appears incorrectly again. If so, this is something to address with NG support.
arnb wrote:It occurs in all browsers; firefox, chrome, edge, opera, and the Orbi app. For the record I use Vivaldi for my go to browser on Windows 10 and Android 9 phone.
- Greg00001Sep 13, 2020StarProblem with netgear is you have to pay for support on shoddy products.
- arnbNov 03, 2020Guide
Updated Router firmware to V2.6.1.36, and Satellites to V2.6.1.38, corrects the Attached Devices issue. However, the BitDefender option is now missing from my RBK43S. Submitted ticket to support.
