arnb
Aug 13, 2020Guide
Missing Devices and Satellites
Installed router and satellites yesterday, Aug 12, 2020 Satellites showed up as connected 5G with good backhaul Devices displayed 7 of 14 attached and working devices Decided to power down the ...
Sep 03, 2020Guru - Experienced User
There was a known problem with v30 FW and the RBS showing disconnected on the RBRs web page. NG pulled v30 from public download. You should update to v16 and the RBS will appear correctly. I experienced the same thing when I had v30 loaded. v16 works fine.
Greg00001 wrote:I've had the same issues as you. Satellites showing disconnected, wrong # of devices listed. Even after factory resets and starting from scratch after each firmware try I always revert to this firmware. It has been the most reliable and stable for me.
Greg00001
Sep 03, 2020Star
FURRYe38 wrote:There was a known problem with v30 FW and the RBS showing disconnected on the RBRs web page. NG pulled v30 from public download. You should update to v16 and the RBS will appear correctly. I experienced the same thing when I had v30 loaded. v16 works fine.
I have no issues with devices on 2.3.5.30 with devices disappearing but I do on later versions, even the 2.5.1.16 you mention.
