stevefxp
May 01, 2019Apprentice
MIssing Networks?
I have a RBR50, RBS50, and a RBW30 in my home mesh Wifi. I have 20/40 MHZ coexistence enabled, so I expected to 9 networks present, but I am only seeing 6. Shouldn't I see a 20/40/80 MHZ network broa...
stevefxp
May 11, 2019Apprentice
Do I need this coexistence when I have IoT devices in my home?
ekhalil
May 11, 2019Master
20/40 MHz Coexistence is about interference. If you have many 2.4 GHz networks in your surrounding (which is usually the case) then it's recommended to allow 20/40 coexistence.
You need to disable 20/40 coexistence only if you have devices operating on 2.4 GHz band and only work with 40 MHz channel bandwidth, which is very unusual, I think!
