Jak29672
Aug 01, 2023Aspirant
Missing Phone Calls on RBR50 Mesh Network
I have an ORBI RBR50 and 2 RBS 50 satellites. The RBR 50 is connected to a Hitron CODA-48 modem. I us AT&T as my cellular network. I am missing a number of incoming calls when using wifi calling. T...
Jak29672
Had a typo - it is a Hitron CODA -45.
Firmware is V2.7.4.24.
House is ranch style approximately 2,900 sf.
Satellites are 40 and 45 feet from ORBI.
Where do I find SIP ALG?
Armor, Parental Controls and Traffic are off. Where do I find IPv6?
Either 20/40 coexistence is on or off. No option for 40.
Preamble reset from automatic to short.
Private wifi - off and iCloud Relay is off.
Get back to me with the 2 questions and anything else I should do.
Router has been rebooted.
Aug 01, 2023Guru - Experienced User
There will be a number behind the 45, 45##.
You might consider updating FW:
For that size of home, you might consider turning OFF one RBS. Having too many can cause problems:
Might turn off both RBS to test to see if phone calls come thru or not with just the RBR alone.
Under Advanced tab/Setup/WAN setup on the RBRs web page.
Under Advanced tab/Advanced/IPv6. It maybe already disabled.
Uncheck the check box next to this and apply sets 40Mhz.
- Jak29672Aug 01, 2023Aspirant
No additional numbers after CODA -45.
When i use the app on my phone, it says there are no updates available at this time.
Turned SIP ALG off.
IPv6 is disabled.
Unchecked box for 20/40 coexistence.
Router has been rebooted.We have
Walls and kitchen appliances seemed to effect the wifi signal at each end of the house so I installed satellites to get better wifi signal at those ends of the house.
We have made a number of changes. How do the changes that have been improve the "hand shake" between cellular calls and wifi calling?
- FURRYe38Aug 01, 2023Guru - Experienced User
The newer FW needs to be applied manually.
Having more signal in a closer area can cause problem and noise on the phone and could effect how the phone operates on wifi and the handling of incoming calls via wifi.
You might run a test with all RBS turned off and have someone call you and see if the phone call comes in normally or doesn't.
Firmware is now V2.7.5.4
I will disconnect both satellites.
How do check signal strength at each end of the house to see if RBR50 is providing a strong signal?
I really appreciate you help and hope this allows us to receive incoming calls via wifi. Don't have a problem with outbound calls.
