clvk07
Mar 15, 2019Tutor
Missing security tab Orbi rbk50v
Have upgraded to the latest firmware but cant see the security tab on the app to enable armor, any suggestions?
CrimpOn
Mar 16, 2019Guru - Experienced User
I do not see a security tab on the Android Orbi app. There definitely IS a menu choice for Security under the Advanced tab on the web interface. Alas, I could not find a way to activate Armor because during the initial setup I told Orbi, "do NOT bug me about this ever again."
Have you tried the web interface?
clvk07
Mar 17, 2019Tutor
dont see any option in security web interface either for armor
