clvk07
Mar 15, 2019Tutor
Missing security tab Orbi rbk50v
Have upgraded to the latest firmware but cant see the security tab on the app to enable armor, any suggestions?
Blanca_O
Mar 19, 2019NETGEAR Employee Retired
Hi clvk07
Can you please confirm the firmware version installed? Please make sure as well that you have the latest Android Orbi app (v2.3) installed. If you already have the latest app, I suggest to uninstall and reinstall the app.
Blanca
Community Team
- clvk07Mar 19, 2019Tutor
Hi
Tried with latest apps on both android and IOS. Firmware version is 2.3032
- CrimpOnMar 20, 2019Guru - Experienced User
I just checked and found that the latest Android Orbie app (2.3) was available on Google Play. Installed it and, sure enough, there is now a "Security" option under "Settings" that brings up the option to activate Armor. As far as I can tell, this option does not appear on the Orbi web interface for version 2.3.0.32
