Jonnybunker
May 25, 2021Guide
Mitsubishi Kumo Cloud Connectivity Issues
Hey everyone - I saw a thread about Kumo Cloud and Orbi that discussed a way to help get connectivity back, by disabling 5G connections / reducing the power. https://community.netgear.com/t5/Orbi...
- May 26, 2021Good news !! Kumo Cloud / Mitsubishi have restored their connection issues. If anyone else was having Kumo connectivity issues from 5/22-5/25 should be back
Thanks !!
Jonnybunker
May 26, 2021Guide
Well your instructions worked really well but you’ll never guess… There was a global outage/system error on all Kumo cloud applications.
They didn’t have any updates or reports about it , but I found out after I did all the troubleshooting and still couldn’t get it to work.
Appreciate the help and learn even more about the router now LOL
May 26, 2021Guru - Experienced User
Hopefully youll be able to get that device connected when they fix the problem.
Good Luck.
- JonnybunkerMay 26, 2021GuideGood news !! Kumo Cloud / Mitsubishi have restored their connection issues. If anyone else was having Kumo connectivity issues from 5/22-5/25 should be back
Thanks !!- FURRYe38May 26, 2021Guru - Experienced User
Thanks for letting us know. Glad all is working well now. Be sure to save off a new backup configuration to file. Saves time if a reset is needed.
Enjoy.
