Jonnybunker
May 24, 2021Guide
Mitsubishi Kumo Cloud Connectivity Issues
Hey everyone - I saw a thread about Kumo Cloud and Orbi that discussed a way to help get connectivity back, by disabling 5G connections / reducing the power. https://community.netgear.com/t5/Orbi...
- May 25, 2021Good news !! Kumo Cloud / Mitsubishi have restored their connection issues. If anyone else was having Kumo connectivity issues from 5/22-5/25 should be back
Thanks !!
May 25, 2021Guru - Experienced User
Hopefully youll be able to get that device connected when they fix the problem.
Good Luck.
Jonnybunker wrote:
Well your instructions worked really well but you’ll never guess… There was a global outage/system error on all Kumo cloud applications.
They didn’t have any updates or reports about it , but I found out after I did all the troubleshooting and still couldn’t get it to work.
Appreciate the help and learn even more about the router now LOL
Jonnybunker
May 25, 2021Guide
Thanks !!
Thanks !!
- FURRYe38May 26, 2021Guru - Experienced User
Thanks for letting us know. Glad all is working well now. Be sure to save off a new backup configuration to file. Saves time if a reset is needed.
Enjoy.
