MIKEBRANGI
Jan 27, 2020Initiate
Mitsubishi Kumo Cloud Connectivity Solved
Hello all, just a quick revisit there was a brief post about connecting Kumo Cloud to the Orbi a couple years back. Netgear said it was not possible but it is. Mitsubishi uses the 2.4 band so to get i...
Jan 27, 2020Guru - Experienced User
You can now also temporarily disable the 5Ghz SSID broadcast while you setup 2.4Ghz only supporting devices as well. Under Advanced Tab/Advanced Settings/Wireless Settings.
Enjoy. :smileywink:
