MIKEBRANGI
Jan 27, 2020Initiate
Mitsubishi Kumo Cloud Connectivity Solved
Hello all, just a quick revisit there was a brief post about connecting Kumo Cloud to the Orbi a couple years back. Netgear said it was not possible but it is. Mitsubishi uses the 2.4 band so to get i...
michaelkenward
Jan 28, 2020Guru - Experienced User
Well done.
You have got the thing to work without going through the hassle of trying to create separate SSIDs, which is "the only answer" according to some disgruntled Orbi users. They are wrong, of course, but you have provided yet more evidence to counter their misleading fixation.
