PSUHammer
Nov 28, 2019Luminary
Mix backhaul Ethernet and wireless with two satellites
Had the RBK50 Orbi setup with a single satellite and added a second so I have one on each floor (basement, 1st floor and second floor). I have Ethernet going to each floor and all terminating to a h...
- Nov 28, 2019
You are "good to go". In most cases, ethernet backhaul is superior to wireless backhaul, especially when the wireless signal has to penetrate walls and ceilings.
scooter456
Dec 13, 2019Tutor
I have a mixed environment of 2 wired backhaul RBS20's satellites, 1 wireless RBS20 satellite, and 1 wireless RBW30. The RBS20 satellite would not for the life of me come up on back-haul. I tried switching devices, patch cables, etc so I finally just let it come up on wireless. That seems to have worked out since I later moved it away from the ethernet plug to be more centrally located. What's surprising is that often devices attach to a much further satellite. I probably have too many satellites for my 4-story town home, but I wanted to make sure I had the best coverate everywhere.
Dec 13, 2019Guru - Experienced User
Is Daisy Chain enabled? Try it disabled.
scooter456 wrote:I have a mixed environment of 2 wired backhaul RBS20's satellites, 1 wireless RBS20 satellite, and 1 wireless RBW30. The RBS20 satellite would not for the life of me come up on back-haul. I tried switching devices, patch cables, etc so I finally just let it come up on wireless. That seems to have worked out since I later moved it away from the ethernet plug to be more centrally located. What's surprising is that often devices attach to a much further satellite. I probably have too many satellites for my 4-story town home, but I wanted to make sure I had the best coverate everywhere.
- scooter456Dec 14, 2019Tutor
Distance between satellites vary between 15 and 45 feet. Some are almost on top of others in the floor above.
- FURRYe38Dec 15, 2019Guru - Experienced User
Be sure to move the closer RBS farther way. 15 feet is too close. 30 feet is recommended starting distance for RBS from RBR.
scooter456 wrote:Distance between satellites vary between 15 and 45 feet. Some are almost on top of others in the floor above.
