neilrlsmith
Jun 05, 2019Aspirant
Mix between access point and MESH - possible?
Hi - bit long winded so please bear with me :)
[My router is downstairs. When we refurbed the house, we ran ethernet cables upstairs and to our separate annexe (which we rent out).
Upstairs - Currently I have an old router connected to the downstiars router and acting as an access point. I have a PS4 wired in to that which is great but the SSID has to be different so we have to log out and then in again. So need best of both worlds - wired access point with an additonal LAN port for the PS4 PLUS a roaming MESH SSID capability. Will the Orbit do this for me?
Annexe - I want another Orbit wired to my downstairs router, a spare LAN for a Smart TV, but this time I dont want roaming but a new SSID (becuase we have guests staying) So ideally I want one product that will do it all (rather than a mesh product upstairs and an old router in the annexe).
Will the RBK23 do all this for me?
Thanks for any help.
The Orbi only provides a single SSID for the entire system. Roaming or not roaming. So You could setup a RBS at the annex portion of the building however it would be using the same SSID as the RBSs use only the SSID name thats configure on the base RBR, wired or wireless. RBS can't be configured as a separate SSID.
Your best bet would be to install a Orbi system for your needs for your side of the home, then LAN wire connect a dedicated AP with LAN ports in the annex portion of the home for those users there. 30 feet is recommended in between base RBR and RBS to begin with depending upon building materials when wirelessly connected.
- neilrlsmithAspirant
Thanks for this. What abiut Guest mode though? Wouldnt that solve the issue?
Guest mode could be enabled however it would be seen for the entire system. You could use guest mode. Guest network has no bandwidth management so any connections would be on the WAN side of the router since Guest Network depends on this. Some have said there is security concerns around Guest Network and access to LAN side recources.
