spalatin1020
Apr 14, 2020Initiate
Mix Orbi Satelites
I want to add another satelites but the same models are pricey in and of themselves. I noticed that there was a model out there that was on special and wondered if I can mix these two together. Orbi ...
Apr 14, 2020Guru - Experienced User
yes you can mix the extenders between the orbi router. and the RBR50 has the best backhaul so all the AC satellites should work.
RBS20
RBW30
RBS30
RBS40
RBS40V
RBS50Y
- spalatin1020Apr 14, 2020Initiate
You are a godsend. I was looking for a while on Google with no luck. Thanks again!
- plemansApr 14, 2020Guru - Experienced User
sorry extenders=satellites.
