mrp12
Mar 29, 2021Aspirant
Mixed Backhaul with Orbi 750
Has anyone successfully set up a mixed backhaul (wired and wireless) sytem with the Orbi 750? I have been able to do it with an Orbi RBK50 system. But, when I plug the ethernet cord into the LAN po...
CrimpOn
Mar 29, 2021Guru - Experienced User
mrp12 wrote:Has anyone successfully set up a mixed backhaul (wired and wireless) sytem with the Orbi 750? I have been able to do it with an Orbi RBK50 system. But, when I plug the ethernet cord into the LAN ports (as the diagrams show and as id doen with the RBK50), the 750 seems to stop looking for wireless satellites (although it then sees the wired ones). I'm in a situation where I need both? Did this break on the 750, or is it set up differently than with the RBK50?
My understanding is that it works exactly the same. (Although I do not have one myself.)
You might get an informed report if the question is posted in the community forum for the AX product line:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
