mrp12
Mar 29, 2021Aspirant
Mixed Backhaul with Orbi 750
Has anyone successfully set up a mixed backhaul (wired and wireless) sytem with the Orbi 750? I have been able to do it with an Orbi RBK50 system. But, when I plug the ethernet cord into the LAN po...
Mar 29, 2021Guru - Experienced User
Mixed works on Orbi AX. It's best to sync the RBS first, then ethernet connect the RBS after wards.
Good Luck.
