pierre22's avatar
pierre22
Mixed Lan with orbi AC3000
I have the following product Orbi AC3000 Tri-band WiFi Router (RBR50) and I would like to create a mixed local area network using a network switch to connect devices such as pc, smart tv, printer and...
  • FURRYe38's avatar
    Those will work find until your ready to upgrade.
    I recommend getting the non (E) versions of the switches.
    I found a bit cheaper pricing by getting used or refurb'd equipment.
    Good Luck.
