pierre22
Jul 27, 2023Aspirant
Mixed Lan with orbi AC3000
I have the following product Orbi AC3000 Tri-band WiFi Router (RBR50) and I would like to create a mixed local area network using a network switch to connect devices such as pc, smart tv, printer and...
- Sep 01, 2023
Those will work find until your ready to upgrade.
I recommend getting the non (E) versions of the switches.
I found a bit cheaper pricing by getting used or refurb'd equipment.Good Luck.
schumaku
Jul 27, 2023Guru - Experienced User
pierre22 wrote:
What do I need to wire such a network in a three-story house by passing the cables through the existing light conduits?
You need to find a compromise between the available space in the installation pipes, cable quality, fire protection in the electrical installation (legal requirements).
