pierre22
Jul 27, 2023Aspirant
Mixed Lan with orbi AC3000
I have the following product Orbi AC3000 Tri-band WiFi Router (RBR50) and I would like to create a mixed local area network using a network switch to connect devices such as pc, smart tv, printer and...
- Sep 01, 2023
Those will work find until your ready to upgrade.
I recommend getting the non (E) versions of the switches.
I found a bit cheaper pricing by getting used or refurb'd equipment.Good Luck.
Aug 07, 2023Guru - Experienced User
A rack?
For?
pierre22
Aug 07, 2023Aspirant
In addition to the switch, I would also install a network disk in the rack to share data, as well as allowing me to extend the wifi signal to places where it doesn't reach.
Or is the switch enough?
- FURRYe38Aug 07, 2023Guru - Experienced User
Something to try out and see.
- pierre22Aug 07, 2023Aspirant
In what sense?
I'm new to networking and wanted to figure out what's the best choice for extending my network and wifi signal by sharing data and a printer.
- pierre22Aug 26, 2023Aspirant
Hello, I would like to buy the netgear gs 308v3 switch to connect to the router and I would need another 5 port switch to connect to the gs308v3.
Which do you recommend?
Browsing on Amazon I noticed that there are two versions gs308 and ge308e, what is the difference?
