pierre22
May 21, 2023Aspirant
Mixed LAN/Wi-FI Local Area Network creation with Orbi AC3000 Tri-band WiFi Router (RBR50)
I have the following product Orbi AC3000 Tri-band WiFi Router (RBR50) and I would like to create a mixed local area network using a network switch to connect devices such as pc, smart tv, printer and...
- May 22, 2023
Yes.
May 21, 2023Guru - Experienced User
any simple unmanaged switch will work.
Just go router----switch/satellites.
I've got it setup on mine with both a unmanaged and a managed switch.
- pierre22May 21, 2023Aspirant
What model of unmanaged switch do you recommend?
- plemansMay 21, 2023Guru - Experienced User
I don't.
I've used several different brands/types of unmanaged switches and they've all worked fine. I used to see reports of issues with them but haven't in quite a while. So pick the one with the ports you needs (plus some for expansion) and go with that.
- FURRYe38May 21, 2023Guru - Experienced User
NG GS-105/108v4 and GS308v3, D-Link DGS-105/108 and HP ProCurve 1400/1800 series switches work for Orbi systems.
This product can be fine for the configuration
https://www.zyxel.com/it/it/products/switch/8-16-24-port-gbe-unmanaged-switch-gs1100-series
or better a switch netgear?
