pierre22
May 21, 2023Aspirant
Mixed LAN/Wi-FI Local Area Network creation with Orbi AC3000 Tri-band WiFi Router (RBR50)
I have the following product Orbi AC3000 Tri-band WiFi Router (RBR50) and I would like to create a mixed local area network using a network switch to connect devices such as pc, smart tv, printer and...
- May 22, 2023
Yes.
pierre22
What model of unmanaged switch do you recommend?
May 21, 2023Guru - Experienced User
I don't.
I've used several different brands/types of unmanaged switches and they've all worked fine. I used to see reports of issues with them but haven't in quite a while. So pick the one with the ports you needs (plus some for expansion) and go with that.
