pierre22
May 21, 2023Aspirant
Mixed LAN/Wi-FI Local Area Network creation with Orbi AC3000 Tri-band WiFi Router (RBR50)
I have the following product Orbi AC3000 Tri-band WiFi Router (RBR50) and I would like to create a mixed local area network using a network switch to connect devices such as pc, smart tv, printer and...
- May 22, 2023
Yes.
pierre22
May 22, 2023Aspirant
I want to create a network like the following that allows me to share files.Home network
In this way I can continue to use the wifi network for mobile devices?
May 22, 2023Guru - Experienced User
Yes.
- pierre22May 22, 2023Aspirant
One last question, since I have to upgrade the network from ADSL to fiber and I have to pass the cables inside the walls, which ethernet cable do you recommend?
- FURRYe38May 22, 2023Guru - Experienced User
CAT6A STP. What I put in wall when I put in a home addition about 10 years ago. Then run CAT6 UTP cabling from wall to devices works fine.
Is the utp 6a cable shielded or should I use the stp one?
(S)hielded Twisted Pair and (Un)shielded Twisted Pair
