pierre22
May 21, 2023Aspirant
Mixed LAN/Wi-FI Local Area Network creation with Orbi AC3000 Tri-band WiFi Router (RBR50)
I have the following product Orbi AC3000 Tri-band WiFi Router (RBR50) and I would like to create a mixed local area network using a network switch to connect devices such as pc, smart tv, printer and...
- May 22, 2023
Yes.
pierre22
May 24, 2023Aspirant
Good afternoon, some devices are about 100 meters away from the switch and the LAN cables should pass next to the electric wires, which cable do you recommend, because they told me that a shielded 7 cable is more performing over 15 meters.
May 24, 2023Guru - Experienced User
CAT6A STP and up will suffice. As long as its STP.
