cbcbd
Feb 23, 2021Initiate
Mixed Network of RBR50, RBS50 and RBS20 Best firmware
I have a Mixed Network of RBR50, RBS50 and RBS20. I have had issues in the past with mixed firmware levels. The current firmware for the 50s is 2.7.2.104, but there is no corresponding firmware versi...
- Feb 23, 2021
That what I'm running:
Feb 23, 2021Guru - Experienced User
- ReallyAnnoyedAFFeb 28, 2021Star
I've got an RBR50, RBS50, RBS20 and a RBW30. I stopped upgrading after 2.3.5.30 (2.3.5.6_1.0.8 on the wall plug) because that was the last decent codebase. I rebooted my router this morning after about a year and now i'm getting prompted to upgrade but I will not.
- vajimFeb 28, 2021Master
ReallyAnnoyedAF wrote:I've got an RBR50, RBS50, RBS20 and a RBW30. I stopped upgrading after 2.3.5.30 (2.3.5.6_1.0.8 on the wall plug) because that was the last decent codebase. I rebooted my router this morning after about a year and now i'm getting prompted to upgrade but I will not.
Good idea
- cbcbdMar 03, 2021InitiateGuru
That is what I ended up doing as well, and it seems to be stable. I will update if issues arise.
Thanks
