madhatter
Mar 28, 2020Apprentice
Mixed satellite models RBR50 + RBS50 + RBS40 + RBS40 Networking issues and Firmware mess
This combination does work ... I have everything on f/w V2.3.5.30 -- so here are the issues: going into Attached devices, I see all 3 satellites going into (Online Update) Advanced | Administration...
Mar 29, 2020Guru - Experienced User
Has a factory reset and setup from scratch been performed since last update t ov2.5.1.8? This version fixes device naming problems of prior versions of FW on the RBR50.
As long as the RBS are on the latest version of FW found on NGs web site, the RBS should all work for you.
