darrenkdean
Jan 15, 2018Tutor
Mixed Wired & Wireless Backhaul
Do the Orbi's support wired backhaul yet? If so, is there a reference guide you can point me to explaining how to set it up? I have an Orbi Router RBR 50, with a total of 3 additional satellites...
tagteam
Jan 15, 2018Virtuoso
The link below is about the only official reference you will find around here.
- AmitRJan 15, 2018NETGEAR Employee Retired
Yes. Mixed backhaul is supported. For example.
Sat1. ---ethernet--- Router --- wireless---Sat2
Router ---ethernet--- Sat1 ----wireless----Sat2
- darrenkdeanJan 17, 2018Tutor
Sort of Good News is that Orbi is showing the hard wired backhaul on the two hard wired satellites. Other news, something has changed.
When I first hooked it up, the two satellites retained their IP Addresses *.242 & *.243 & connected devices began showing up under them. A few hours later, I logged into the Orbi to find that the IP Address of the satellites have changed to 192.168.1.250 & there are no connected devices showing up. Strangely, I can still hit the Satellites' GUI's by going to the *.242 & *.243 addresses. The 192.168.1.* address space does not exist in our network. The only device carrying this address space is the AT&T Gigapower Modem.
Orbi is setup in Access Point Mode, runs into a Cisco 3750G-24TS 3L switch, & receives DHCP, DNS, from a Microsoft Server 2016 domain controller.
Any thoughts on what is going on here?
- budyJan 17, 2018Luminary
Yeah… this is the same way, my wired sat is being shown on the router's attached devices page. However, it seems that this is only a glitch in the Orbi's UI. When I log into the sat via telnet, that 192.168.x.x address is nowhere present in the system.
