Bigfish99
Nov 06, 2022Follower
Mixing a RBR10 with ?
Home network. Trying to get ethernet to a wireless TV to get 4K. I have a: Orbi RBR10 Running v2.7.4.24 What other add-on satellites can I use? Thanks!
- Nov 06, 2022
There's no other way to put this: you are sort of screwed.
Because of the way the "10" product was designed (a "Dual Band" rather than a "Tri Band" system), the only satellite compatible with the RBR10 router is the RBS10 satellite, which has no Ethernet port.
However, all is not lost. Are you absolutely certain that the TV will not stream 4K video over WiFi? If the issue is signal strength, maybe an RBS10 in the same room as the TV would boost the signal enough.
Another solution might be to use either a WiFi to Ethernet adapter or a WiFi Extender with an Ethernet jack on it, such as the Netgear EX3700.
CrimpOn
Nov 06, 2022Guru - Experienced User
