rkeidar
Mar 30, 2019Follower
Mixing old router (RBR20) with new satellites
Hi, I have RBR20 router with one RBS20.
I want to add a setellite. I can get a use one from eBay , the questions are:
1. Would RBR20 have any issue to work with newer satellites RBS40 or RBS50? ...
ekhalil
Mar 31, 2019Master
Yes, the RBS40 and RBS50 can be connected as satellites to an RBR20
rkeidar wrote:
2. Netgear seems to have some pre-assigned pairing for satellites with the router that came in same box unless they are tagged as 'Add-On'. Is there a real limitation that preventing pairing a satellite with a router that is not its original pairing?
Any Satellite -if not pre-synced- can be synced with a Router by pressing the Sync button on both the Router and the Satellite. So yes you can buy a pre-owned Satellite and connect it to your existing Router.
