pdmartin
Jul 16, 2020Aspirant
Mixing RBR50 with RBS50 and RBS20
I understand that if use wireless backhaul and I mix RBR50 with an RBS20 then the backhaul of the entire system will drop to 866Mbs. So my RBS50 will also have a backhaul of only 866Mbs. My ques...
Jul 16, 2020Guru - Experienced User
The connection rate doesn't fall to 866 for the RBS50. Only the RBS20.
You can mix the RBS connections. 1733Mbps is the connection rate for the RBS50 when wireless conencted.
Disable Daisy Chain on the RBR.
pdmartin
Thanks for the fast reply.
Am I right in thinking though that if I use the RBS20 with wifi backhaul that it would slow the RBS50 down to 866Mbs backhaul? i.e. I will only get the full backhaul on the RBS50 of 1733Mbs if I wire up the RBS20.
Thanks
Paul
