Dominich
Aug 13, 2019Aspirant
Mobile Phone Signal Interference
Hi,
Ever since I set up my Orbi Wifi mesh system - my Mobile Phone (Samsumg Android) service / phone call clarity has deteriorated. It only happens when I am in the same room as Router (Nighthawke D7000 and the new Orbi system) - and its only started happening since I set up the satelite system? Is it possible the new mesh system intereferes with my mobile reception?
If you set modem mode on the Modem, then power the Modem and Orbi OFF for 1 minute, then back on with the modem. Let it sync. Power ON the RBR. With a wired PC connected to the RBR, check for internet access. If still nothing, I would factory reset the RBR and setup from scratch and walk thru the setup wizard while the modem is in modem mode. The RBR should get connected here.
No. Completely different frequencies from cell phone frequencies.
Disable wifi phone all support and see if this helps.Is the modem configured for modem only mode? Your modem has wifi and a built in router here as well. It should be configured for modem mode if your going to use the Orbi has your main router and wifi system.
Dominich wrote:Hi,
- DominichAspirant
Hi,
I logged into my Nighthawke Router and switched to "Modem" only - and now I have no intrnet at all. I am currently online via Mobile Phone. Not sure now how to restore so I have internet and use Nighthawk as Modem only?
