Gebla
May 25, 2019Apprentice
Mobiles and laptop do not have internet
My family has many issues with mobiles and laptops (surface Book and Surface Pro) not getting internet on a Orbi setup. Wifi is connected but no or very slow internet connection. Using latest firmwar...
May 26, 2019Guru - Experienced User
What FW is currently loaded?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Try enabling WMM, Beamforming and MIMO. Under Advanced Tab/Advanced Settings/Wireless Settings
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Disney Circle: https://community.netgear.com/t5/Orbi/WARNING-Firmware-2-2-1-210-is-junk/m-p/1667485/highlight/true#M45926
- GeblaMay 26, 2019ApprenticeI tried all these settings but no change. Daisy chain i cant disable as one rbs50 will not work.
20/40 is only affecting 2.4 I believe- FURRYe38May 26, 2019Guru - Experienced User
Daisy chain needs to be disabled if you have a wire connected RBS.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.- GeblaMay 26, 2019ApprenticeYou are joking, fiasy chain does not work? Why is the connection setup working then. The app shows a working condition. With one wireless rbs50 connecting to a wired RBS50.
House is 1800 square feet. Distance is around 30 ft
