John_Ba
Apr 22, 2021Luminary
Modem access throuh] router
Its not needed often but in the past I have had to get line stats from my modem. My RBR50 blocks access to my Vigor 130 and when, as just had to do, I need line stats for my ISP I have to get then di...
CrimpOn
Apr 22, 2021Guru - Experienced User
John_Ba
The modem is as out of box with no changes to defult
- CrimpOnApr 22, 2021Guru - Experienced User
John_Ba wrote:The modem is as out of box with no changes to defult
Thank you. That being the case, the Orbi WAN interface should have an IP of 192.168.1.???.
All the devices on the Orbi LAN would have IP addresses of 10.0.0.??
A web browser asking for 192.168.1.1 (the modem) should connect to it.
I am as puzzled as you are why this is not happening.
- FURRYe38Apr 22, 2021Guru - Experienced User
FURRYe38 wrote:Try the modem in bridge mode?
When the modem web interface is not reachable, it might be hard to change the mode. The issue is retrieving usage stats from the modem. I did not read the manual far enough to learn if usage stats are collected in bridge mode.
Would be curious if the bridge mode supports 192.168.100.1 or not. Even if the modem isn't bridge, it's web page should be accessible thru the Orbi.
They would need to connect a PC to the modem and change it there if bridge mode is an option.
