LauraAMayer
Oct 22, 2020Aspirant
Modem for RBK44
What modem is best for the Orbi RBK44 since I am on a satellite service with ViaSat?
usually viasat requires their own gateway for service.
What gateway do you have?
some have their own integrated router.
Ask ViaSat what it supports or allows.
Netgear won't have a clue on things like that unless it sells a compatible modem.
https://community.netgear.com/t5/Cable-Modems-Routers/What-s-the-Difference-Between-a-Cable-Modem-and-Cable-Modem/m-p/1864698#M21950
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-Mode
LauraAMayer wrote:What modem is best for the Orbi RBK44 since I am on a satellite service with ViaSat?
