golf22grg's avatar
golf22grg
Follower
Aug 19, 2020
Modem Recommendations for Comcast Xfinity
Moving into a new home which has Comcast Xfinity internet.  Current running the Orbi RBR50 with one satillite in my current house which is 4600 sq ft.  Which modem should I buy that will work well with the Orbi RBR50?  New house is a ~5400 sq ft so I need to cover some ground!  I like superfast internet so don't want anything that will limit me in the furture.  TIA!
    • Wahuwa73's avatar
      Wahuwa73
      Will the Netgear cm1159 work also with Comcast/Xfinity? I have a Comcast voip phone line.thx!
      • FURRYe38's avatar
        IF you mean the CM1150v then it should. Something to ask the ISP to be sure. ISP have a list of what is supported.
        Good Luck,
