cjc182
Apr 28, 2020Aspirant
Modem to accompany my Orbi RBR50
Hi, I have an ORBI RBR 50 with an ORBI satellite. I use a rented Xfinity modem but would like to replace it with with my own modem. The Xfinity modem is an ARRIS T25 cable modem with voice. Can so...
Apr 29, 2020Guru - Experienced User
IF you need phone support with the modem, you can review NetGears CM1150v modem. Has phone support if you need this feature. Make sure the ISP you have supports it.
cjc182 wrote:Hi, I have an ORBI RBR 50 with an ORBI satellite.
Can someone suggest a modem that would work well with my Orbi set-up?
Thanks.
cjc182
May 16, 2020Aspirant
Thanks for the recommendations, especially on the Comcast-approved SB8200.
II will look into it.
