Red1Sierra
Oct 29, 2019Aspirant
Modern Warfare Orbi RBR50 XboX
Just got modern warfare for Xbox. Was able to connect for a day. Then not at all only to modern warfare. All other games work great online. Reset router to factory. Same issue. Turned on phones hotspo...
Red1Sierra
Using netgear cm500 cable modem. Using latest firmware update on orbi and I’m running over wireless. Just reset the router to factory settings. NAT is open on Xbox and all other games run fine. Just this specific game won’t connect to online services within game.
Oct 29, 2019Guru - Experienced User
The game is new and there maybe game services issue. If other games work and MW doesn't then this points to a game issue and not a router issue. I was gaming the other night for hours with my roommate. Two game consoles wired behind the RBR50. NAT Filter set to OPEN since we have two console online at the same time playing same game. You don't need this if you only have 1 console online at a time.
Your NAT is good and your modem doesn't have a built in router so your good here.
It's a big game and getting popular. Just seems to be a game service issue rather then a router issue. I see one of my gaming buddies online right now. So something is working for others.
Make sure your ISP modem is getting good signal. Have the ISP check the signal and lne quality up to the modem.
Be sure there are not coax cable line splitters between the modem and ISP service box.
