Robloch
Apr 09, 2020Aspirant
modifier manuellement adresse IP fixe
Je ne peux pas acceder à certains site parfaitement classique et un erreur 404 s'affiche. Je comprend qu'il faut donner un adresse IP fixe à min routeur mais je ne trouve pas le moyen de le faire. Mo...
Apr 09, 2020Guru - Experienced User
en anglais s'il vous plaît
Robloch
I do not find any answer to my current issue : error 404 on some classical internet websites.
I understood that it was linked with IP address and the fact that these websites required fixed adress. My internet provider is Free and my box is Revolution (Free). Is somenone can guide my to manually modify my IP address ?
- FURRYe38Apr 09, 2020Guru - Experienced User
What NG product are you referring too?
Sounds like something you need to contact your Internet Service Provider about...
Robloch wrote:I do not find any answer to my current issue : error 404 on some classical internet websites.
