jefftechaz
Jun 04, 2019Aspirant
modify ssid's for guest network
wl_ssid and wla_ssid work for modifing the standard network, what parameters are for the guest network?
wl1_ and wla1_ didn't work
1 Reply
Given that you understand that modifying Orbi parameters using telnet (a) is not supported by Netgear, and (b) may have all sorts of unintended consequences, here is what I found when I did a telnet to my Orbi and typed "nvram show".
wlg1_ssid=MyGuest
wla1_ssid=MyGuestI had entered "MyGuest" as the name of my Orbi guest network. (I personally use Putty and have set it up to log the entire session to a text file, which I then dumped into a text editor and searched for "ssid".) There are a bunch of parameters with "ssid" in them. Have no idea what they all do.
p.s. I would have my paperclip at hand in case the Orbi needs to be factory reset.
