agaurav
Aug 28, 2021Aspirant
Monitor websites visited on Orbi 6 wifi
I have an Orbi RBR850 and a satellite system. I want to monitor what website is being visited by each device on the home Wifi system. I can see the logs in the orbilogin.com (10.0.0.1) in Advanced me...
CrimpOn
Aug 28, 2021Guru - Experienced User
I think you may frustrated in this endeavor.
My Orbi is the original model, not the "AX" you are using (which has a separate community forum where someone may have a better answer than mine: https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax )
On my Orbi, in the Advanced Tab, Security Menu, there is page for "Block Sites". I went to that page and said to block any URL with the term "sexykitten". Then, I opened a web browser, which opened several web pages and I attempted to open www.sexykitten.com". This failed, although I do not know if it failed because of the block or because there is no such web page. (Maybe I should have blocked something that actually exists.)
Then, I looked in the Orbi log and saw this:
192.168.1.2 is my PC. Notice that the act of blocking one URL term has flooded my Orbi log with everything connection made from my PC to anywhere. Opening one web page quite often results in web connections to dozens (hundreds?) of URL's. The log will fill almost immediately. My Orbi is set to email the log to me when it fills. I cannot imagine how many emails would result.
I have a fear, however, that even if your AX Orbi will act the same, this will not accomplish what you want because when users have attempted to use Block Sites as a primitive form of Parental Controls it turns out that Block Sites does not block https (secure) connections.
You might want to experiment with Block Sites and see if it does anything remotely like what you want on the AX model.
I have no idea what Parental Controls logs about connections, as I have never enabled it. (My parents have passed away, and I no longer need to control what they do on the internet. -sick humor)
agaurav
Aug 29, 2021Aspirant
This is great info. I turned on blocked site feature and picked an authentic site and then tried to access it. The site did show up in the logs coming from my computer's IP address. So that is great.
[site blocked: microsoft] from source 10.0.0.19 Sunday, Aug 29,2021 05:08:33
Now, if only such lines in the log were generated for all sites being visited by source on my Wifi network. I don't want to block all sites. I want sites to be allowed but still be logged. I don't see that happening yet.
- CrimpOnAug 29, 2021Guru - Experienced User
This could be an area where the AX product is different from the original Orbi.
On my Orbi, the Advanced Tab, Administration menu, Logs has various catagories that can be enabled.
(see attached picture)
- agauravAug 29, 2021Aspirant
I have the same settings like your screenshot but none of those show up in the logs. Only the blocked sites show up. Nothing else. Its almost as if the router isn't saving those to the logs.
Dang. I haven't helped much. Sorry.
If you have not activated Parental Controls, you could sign up for the free trial and see if that collects history by device.
(I really wish there was a User Manual for Parental Controls. I have never found one.)
The DNS process has features that interfere with what you want to accomplish. Most computers keep a DNS cache of URL's that have been used before and refer to the cache before sending a DNS query. So, after my PC learns the IP address of disney.com, it will not try to resolve that again until the URL 'expires'. So, you can see that a device went to sexylady.com at least once, but not how many times.
And then there is the horrible part about computers: the user is often able to change their device to point to whatever DNS service they want, which means that the Orbi and the custom DNS service will never see their requests. The newer browsers are now offering to "completely hide" DNS requests inside encrypted packets.
If you really (seriously, really really) want to attempt gathering a record of every web link accessed at least one time by every device on the network one way to do that is to replace Orbi's DNS server with a third party device. For example, I have Pi-hole installed on a Raspberry Pi. In the Orbi configuration, I point the Orbi at the Pi-hole IP. Pi-hole records queries and reports what it did with each of them. (see two attachments) Pi-hole keeps a long term record that can be searched, sorted, etc.
Pi-hole is just one of many DNS servers that can be installed locally. With any of them, the project can be a challenge:
- Buying and setting up the hardware.
(it is possible to 'host' Pi-hole on Amazon, but I have no experience with how well it works or how difficult it is to set up.) - Getting the hardware running and on the network.
- Installing or activating the DNS service. (In my case Pi-hole)
- Pointing Orbi to this DNS (that is the easiest part of all)
- Learning how to extract logs and turn them into useful data.
If the goal is general knowledge, it might accomplish what you want. If the goal is control, I am not confident it can be done.
