Noisenet
Mar 17, 2018Tutor
Months of solid performance now daily disconnects - what gives?
I bought this Orbi system (one satellite - the RBS50) several months ago, it's performed with no glitches whatsoever. Now it's dropped the connection the last two days, out of nowhere, requiring a po...
Noisenet
Mar 17, 2018Tutor
Thank you! I've downloaded the files, I have to head to work soon so I'll do the downgrades tomorrow for the router and satellite.
Will I need to telnet in and disable automatic updates or will me updating automatically disable the automatic feature (I've seen people reporting both behaviors).
Thanks again!
Jgriesshaber
Mar 17, 2018Tutor
Reverting back firmware will not auto update, as they have paused any updates to the 2.1s as they are clearly broken.
Make sure to update your satellites first, then the router.
- FURRYe38Mar 18, 2018Guru - Experienced User
Let us know how it goes.
