ITTOG
May 10, 2021Tutor
Motorola Modem MB8611 Will Not Work with Orbi
Does anyone know if there are any modem's Orbi will not work with? I am having issues with the modem whenever I connect my router. If I connect a laptop to the modem everything works great. But onc...
CrimpOn
May 10, 2021Guru - Experienced User
ITTOG wrote:Does anyone know if there are any modem's Orbi will not work with? I am having issues with the modem whenever I connect my router. If I connect a laptop to the modem everything works great. But once I connect my router the modom loses its connection to the internet. Sometimes the modem will bounce off and on. I have tried too many variations to list on when I power on the router.
This modem appears to be entirely compatible with the Orbi router. The Quick Start Guide is typical of modern modems. After the modem's OnLine symbol lights up what color does the ethernet connection show (green for gigabit)?
https://motorolacable.com/documents/MB8611-QuickStart.pdf
Is the same ethernet cable being used for the laptop test and for the router connection?
- ITTOGJun 01, 2021Tutor
It is green. I have been using the old modem since my first posting. The behavior of the orbi has changed. Now, I experience the wifi being connected but no internet access. It is ineresting though because my wired devices do not lose connection to the internet, only the mobile devices. This behavior cycles throughout the day. Very weird behavior.
