ITTOG
May 10, 2021Tutor
Motorola Modem MB8611 Will Not Work with Orbi
Does anyone know if there are any modem's Orbi will not work with? I am having issues with the modem whenever I connect my router. If I connect a laptop to the modem everything works great. But onc...
May 10, 2021Guru - Experienced User
Did you power OFF both RBR and Modem for 30 seconds, then back ON with the modem first then RBR?
NGs CM series modems work with Orbi systems.
