KaaSerpent
Jan 17, 2022Aspirant
Moved Orbis to UPS, now one satellite is very slow
I purchased and have been using an Orbi RBK53S-100NAS system in October of 2020. Since installing, we've enjoyed high speed Internet access throughout the house. I have gigabit service and we have be...
KaaSerpent
Jan 18, 2022Aspirant
The UPS is on the floor below the table where the router and base unit are located. The satellites are upstairs, and neither of them have the UPS directly below them (between the satellite and the base).
Jan 18, 2022Guru - Experienced User
what ups is it?
- KaaSerpentJan 18, 2022Aspirant
We bought two APC Back-UPS BE425M and one with a higher rating (can't find the box/manual so can't remember except that it was higher). The router + base Orbi + one laptop are plugged into one of the new 425s and the two ofices upstairs have higher wattage. One is a new APC one and one is a relatively new CyberPower. I did the math on wattage and the ones we bought SHOULD be sufficient.
- CrimpOnJan 18, 2022Guru - Experienced User
There is one obvious test: Reconnect the two installation to wall power. (i.e bypass the new UPSs)
No UPS: "No Problem". or....... it's not the UPS.
